It is currently Wed Aug 06, 2025 9:08 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 13, 2018 2:34 pm
Great job
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
That came out well. Nice job! If you want to disguise it even more you can use a very fine paintbrush, or a sharpie pen, to 'paint' some figure/grain lines that cross the line of the repair and visually tie the patch and the surrounding timber together. It only has to be subtle, but it distracts from the un-natural boundary of the edge of the graft.
PostPosted: Wed Jun 13, 2018 3:22 pm
Looks good. Mohawk makes graining pens to add the line Mark mentioned. Or a colored pencil of the appropriate color can also work. There is a grain line that intersects with the middle of the patch, if you can visually pull it across the patch it will help hide the repair.
PostPosted: Wed Jun 13, 2018 9:25 pm
City: Tyler
Aced that! You’ll never notice it.
PostPosted: Wed Jun 13, 2018 10:12 pm
Well, I think YOU will notice it under a finish, but no one else will ;)
PostPosted: Thu Jun 14, 2018 12:41 am
Last Name: Blower
City: Keighley
State: West Yorkshire
Country: UK
As above, looking good, only you will know where the damage was.
If you’re routing the binding ledge, going over the repair will be exciting. Good luck.
PostPosted: Thu Jun 14, 2018 6:25 am
First name: Mark
Last Name: McLean
City: Sydney
Steve has a good point about the danger of running a router across that glued-in fragment. It might be a good idea to stop the router a little way either side of the repaired area, and then do that segment by hand with a chisel or fine saw.
PostPosted: Thu Jun 14, 2018 6:29 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I think you made the right decision - looks great and will go away under the finish
Ed
PostPosted: Thu Jun 14, 2018 10:45 am
I would reinforce it with some wood 'tape' where it is not covered by the linings. Then you probably wont have to worry about the rout.
Users browsing this forum: Bing [Bot] and 16 guests
